Print at Oct 20, 2026, 4:49:38 AM
Posted by Keet at Jan 19, 2026, 5:56:43 AM
Re: Custom Model Editing Using Walls & Floors
Our very respected member Dorin saves your day!
He just released the beta-2 version of his new MBC plugin (Boolean Operations). Download and read about it here .
With that plugin you can create your recesses on both sides very easily: create a shape with the Shape Generator plugin that represents the recess on a side of the panel. This represents the "air" that the recess fills.
Rotate/tilt the recess shape you created into the head board where the recess must be. Select both board and shape and start the MBC plugin. Choose the "Difference" action and run it. What it creates is your head board with the recess cut out of it! Repeat for the other side.
