Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Moulding Boolean Convert plugin (MBC) » » » » Post: Re: Moulding Boolean Convert plugin (MBC) |
Print at Oct 20, 2026, 12:39:24 AM |
| Posted by dorin at Jan 19, 2026, 11:33:15 AM |
Re: Moulding Boolean Convert plugin (MBC) @Keet Your approach presented here is brilliant! Basically, you need to make a negative of the hole you need. Then you subtract it from the main object. Brilliant! I've already done a few tests, it's not exactly simple but not impossible. The result is acceptable. This way, part of the smoothing can be solved (using a cylinder, torus, or some of the modeling library). A tip: save and reopen the application from time to time. Will free the temporary memory. This gave me the opportunity to discover a few more tricks. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 20, 2026, 12:39:24 AM |
