Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: textures » » » » Post: Re: textures |
Print at Oct 2, 2026, 11:11:05 PM |
| Posted by db4tech at Aug 5, 2010, 10:04:31 PM |
Re: textures Ah yes I understand what you mean although I'm not sure it would bend time (4d) well apart from the long render time required. ![]() I already tried making a highly subdivided Spline mesh, with alternating faces removed, reduced in size, then cloned and joined several times. it creates quite a large and slow to render model because so many calculations are required. A bit like the holes in my lamps, where many extra light path calculations are required. So I would imagine that is why they use bitmaps to help simplify and reduce the number crunching process. With bitmaps only using one poly or two triangles for a flat surface it keeps things very simple. Ideally vectors would be better so they were resolution independent, plus the model file sizes would be smaller, but I guess at the moment it would add to much extra processing? db4tech |
Current timezone is GMT Oct 2, 2026, 11:11:05 PM |
