Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Null Pointer Exception from Linux Debian version » » » » Post: Re: Null Pointer Exception from Linux Debian version |
Print at Sep 23, 2026, 2:32:08 PM |
| Posted by JosLouis at Jan 29, 2026, 12:28:35 PM |
Re: Null Pointer Exception from Linux Debian version Strange Observations 1- Shortly after trying SH3D and getting the above problem, I ran out of disk space. After investigation (du -hsx /var/log | sort -rh | head -10), I found out that syslog had swelled to 62G. I had to purge syslog to avoid formatting. This has not occurred since. 2- A similar problem occurred before (https://sourceforge.net/p/sweethome3d/bugs/346/) caused by lack of disk space and caused a Null pointer exception. 3- Another case was confirmed using the Pan view plugin and SH3d would not start (https://bugs.launchpad.net/ubuntu/+source/sweethome3d/+bug/1442958). actionparsnip (andrew-woodhead666) said on 2026-01-28: #2 https://www.sweethome3d.com/support/forum/viewthread_thread,5072_offset,10 Some kind of race condition? (I just googled the error you are getting).... 4-./SweetHome3D-Java3D-1_5_2 &> ~/SH3D_jre1.8.0_481.txt does not redirect standard error to the file but to the screen. 5- Retried the original tests from a fresh install with default runtime and then with jre1.8.0_481 and got the same error condition. Launchpad Question: https://answers.launchpad.net/ubuntu/+source/...upgrader/+question/823479 |
Current timezone is GMT Sep 23, 2026, 2:32:08 PM |
