ESC key issue
This topic has been viewed 7887 times and has 3 replies
mikimichele82
Country: Italy
ESC key issue
Post by mikimichele82 »
Good morning,
I have just installed the plugin and run some tests.
The lines are drawn correctly on the 3D view, but if I press the ESC key while the plugin is active, I can no longer draw any dimensions and I can’t go back.
Is this a known bug, or is there a way to restore the creation of the dimension lines?
Thanks in advance
Michele
Re: ESC key issue
Post by Keet »
It might help if you mentioned which plugin.
mikimichele82
Country: Italy
Re: ESC key issue
Yes, you are right!
I due a mistake: it was my first time in the forum and Ia pressed “New Thread” instead of “Reply” in a previous conversation.
Anyway thanks for your reply and the plugin I refers to is “3D dimensional lines”.
Thanks
Michele
Daniels118
Country: Italy
Re: ESC key issue
Post by Daniels118 »
Quoting myself:
I know there are bugs using the plugin with the latest versions of SweetHome3D. I haven't had the time to fix them, so the only chance is to use the native dimension lines, or downgrade SweetHome3D to a previous version (7.0 should work fine).
Keep in mind that native dimension lines can be placed vertically using the edit dialog.
