Print at Sep 29, 2026, 6:31:24 PM
Posted by bsyap at Aug 12, 2010, 3:00:41 AM
Re: How do i build a SweetHome3D v 2.5 source project?
Hi Puybaret,
Thanks for the reply and tips, i am coming from a c# background where i build most of my project using MVS2008. I have learned Java language before, build my Java program in very "old-school" way, TextPad wink
Yes, i have followed your instruction and try to run it again, but it failed too.
1)I am using the source project(CVS tar zipped file ) where i downloaded it through http://sweethome3d.cvs.sourceforge.net/viewvc/sweethome3d/SweetHome3D/ , am i getting the correct source project ?
2)Then i try to download another source project from http://sourceforge.net/projects/sweethome3d/files/ and try to run it, i did not received an UnsatisfiedLinkError Exception but i get another new exception so called :
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Users\Boon Shyang\workspace\SweetHome3D\lib\windows\j3dcore-ogl.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
3)I am running the source code in Windows Vista-64bit. In MVS2008, i can run this project in either 32 bit and 64 bit, but can i do the same thing using Eclipse IDE? Or should i go for other IDE such as Netbean? Perhaps, using a Java2C# convert tool?
Any help is greatly appreciated. Thanks smile
Regards
bsyap
