Print at Sep 29, 2026, 7:15:21 AM
Posted by Puybaret at Aug 12, 2010, 9:12:15 AM
Re: How do i build a SweetHome3D v 2.5 source project?
As you're able to build the project without errors, you have the correct source wherever it comes from. The only difference is that you can retrieve the current version with CVS whereas the SourceForge.net download section contains only the released versions.
The exception you got suggests that Eclipse has some problems to run Java 3D 32 bits DLLs. I guess it fails because you installed a 64 bits JDK on your computer. If you replace it by a 32 bits environment (including Eclipse one), you'll be able to run Sweet Home 3D in the same environment as the one available for download.
You may also replace the 32 bits DLLs found in the lib/windows subdirectory of the project by their 64 bits version found here. I'll be pleased to know if this second solution works correctly.
