Print at Oct 20, 2026, 12:54:18 PM
Posted by Keet at Feb 2, 2026, 11:21:23 AM
Re: Wall width does not match the entered width
The length of a wall is measured from the start and end points of the center line of the wall. When you connect a wall to one end the start point shifts halfway the thickness of the wall you connect to (the center line of the connecting wall). Measuring the outside of the wall should still be the same.
There have been numerous discussions about why the center line is used. There are good technical reasons for this but you need to get used to the concept.
