Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: split wall horizontally? » » » » Post: Re: split wall horizontally? |
Print at Oct 21, 2026, 1:41:12 AM |
| Posted by Keet at Feb 9, 2026, 9:21:06 PM |
Re: split wall horizontally? There are two ways: 1. Use the baseboard options which you can find n the Modify Walls dialog. This method has the advantage that you keep a single wall but a baseboard has a minimum thickness of 0.1mm so it will stick out a little. If that is no problem than this is the best option. 2. Another method is to create the lower wall with the height of the lower part you want. Then add a level with an elevation of that <lower wall height> + <the floor thickness of that new level>. (A wall sinks down with the floor thickness). Copy your lower wall and past it on the new level. Set its height so it reaches the height of your lower level. Basically you put two wall on top of each other without a floor. Now you can texture each wall separately. For the single row of tiles look at the available wall textures. There are textures that have such a tile row. If that is not sufficient than use method 2 but at an extra level where the 'middle wall' is for the decorative tile row. Set the floor thickness for that level low because the actual wall height will include that thickness. To understand how levels, wall heights, and floor thicknesses work you can read my manual Levels explained ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 21, 2026, 1:41:12 AM |
