Sweet Home 3D keeps loading hidden recovery files, freezes
This topic has been viewed 17584 times and has 3 replies
[email protected]
Country: Nederland
Post by [email protected] »
Hello,
I am experiencing a persistent problem in Sweet Home 3D: every time I start the program, it automatically attempts to open restored files from a previous session, which causes the program to freeze immediately.
The original project file is over 71 MB, and there are 4 restored/recovery files of similar size, which I believe is why the program locks up when attempting to open them.
I have already tried the following:
Closing Sweet Home 3D completely via Task Manager.
Moving or renaming the configuration folders in:
C:\Users\<my username>\Documents\Sweet Home 3D
C:\Users\<my username>\.SweetHome3D (hidden folder)
Performing a full uninstall and reinstall of Sweet Home 3D.
Starting the program via a “clean” temporary folder using a modified shortcut (“Start in” set to an empty folder).
Searching for .sh3d files on my system and temporarily moving all restored or recent files to a backup location.
Despite all of the above, Sweet Home 3D still opens these invisible restored files and freezes on startup.
Could you please advise how to fully reset or clear the internal restored files cache so I can safely start the program without it automatically loading these files?
Thank you for your help.
Re: Sweet Home 3D keeps loading hidden recovery files, freezes
Post by dorin »
I'm a linux user but, your path is not OK for WINDOWS.
SH3D, under WINDOWS have the working path at:
C:\Users\User\Application Data\eTeks\Sweet Home 3D
Under this folder you have some other folders:
-furniture
-languages
-plugins
-recovery
-textures
-work
and the preferences file.
Navigate on this path (don't ask me how to do under WINDOWS) and delete work & recovery folders.
Usually it appears only when you open an existing .sh3d file.
Don't worry, will be recreated when needed.
Probably this could solve your problem.
Good luck!
keirastevenson
Country: United Kingdom
Post by keirastevenson »
This discussion highlights a frustrating Sweet Home 3D issue where hidden recovery files cause the application to freeze during startup. The suggested solution is to locate and remove the work and recovery folders, allowing the software to recreate them when needed.
Similarly, The Research Guardian Reviews can help people explore service feedback, understand customer experiences, and make informed decisions. Reliable information and transparent reviews are valuable when evaluating research support services and choosing an option that meets individual needs.
jacobaxter
Post by jacobaxter »
It sounds incredibly frustrating to deal with Sweet Home 3D freezing up like that! I've had similar issues with other design software when large recovery files bog things down. It makes you wish there was an easier way to manage those temporary files or a built-in "safe mode" to open the program without loading previous sessions. Hopefully, you can find a workaround soon. For anyone else encountering software glitches, sometimes checking community forums like those on the Fnaf platform can offer quick solutions or alternative approaches you might not have considered.
