Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Why is a box visible partially only? » » » » Post: Re: Why is a box visible partially only? |
Print at Sep 29, 2026, 1:25:24 PM |
| Posted by Puybaret at Aug 14, 2010, 10:28:16 AM |
Re: Why is a box visible partially only? If all your walls are 296 cm high, you can also choose Edit > Select all menu item, then Plan > Modify walls... menu item, and enter 296 in the Height text field. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 1:25:24 PM |
