Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Modeller 3D plugin » » » » Post: Re: Modeller 3D plugin |
Print at Sep 23, 2026, 2:32:02 PM |
| Posted by dorin at Mar 24, 2026, 7:02:45 AM |
Re: Modeller 3D plugin @Xlance 1. It works from the first attempt. Good job! 2. Almost all controllers works as expected. 3. The generated object is relatively OK. Suggestions: 1. You could start your own tread for this as stand alone application. It deserve it. 2. The exported objects have a default transparency 0.8. You could add a transparency slider. 3. "Launch Shape Designer" button give "...ShapeDesigner-2.0.0.exj does not exist!". You could pack it inside of this application. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 2:32:02 PM |
