Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Objects lose transparency when grouping » » » » Post: Re: Objects lose transparency when grouping |
Print at Oct 2, 2026, 12:19:47 PM |
| Posted by Puybaret at Aug 22, 2010, 11:36:48 AM |
Re: Objects lose transparency when grouping Thank you for your feedback Hans. I didn't succeed to reproduce the two bugs you mentioned. Could you check if it happens with version 2.5 run with Java Web Start too, please? Does the second bug happen also when there's only one window in the wall? [Edited the message to fix the link] ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 12:19:47 PM |
