Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Objects lose transparency when grouping » » » » Post: Re: Objects lose transparency when grouping |
Print at Sep 30, 2026, 9:53:02 PM |
| Posted by db4tech at Aug 22, 2010, 3:12:59 PM |
Re: Objects lose transparency when grouping Thank you Emmanuel, I've not had chance to try this yet, this bug fix will be a great help, for my multi level gallery model! I am currently having to use carefully placed boxes, to fill the gaps in-between upper and lower doors, placed inside the invisible wall furniture model. ***** Hi Hans, Would trying the built in 'Create photo' on the Fast setting, help test to see if the missing door reappears, or if it is a driver problem? I've not looked at the code for built in Create photo yet, so I don't know if it is created using a basic shader, or retrieving an OpenGL 3D render direct the from the GPU (for anyone reading this who might not know. GPU = Graphics Processing Unit) If the Fast render is a retrieved GPU render, then trying the Best setting should help prove whether or not it is a driver issue. ***** By the way, which version of Ubuntu are you using, 10.4.1? I mght download and try it (will be in a virtual machine though) and see how it goes. You will be able to help me then, as I'm not that used to Linux. ![]() Hope you're both well and having a nice weekend! db4tech |
Current timezone is GMT Sep 30, 2026, 9:53:02 PM |
