Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Modeller 3D plugin » » » » Post: Re: Modeller 3D plugin |
Print at Sep 23, 2026, 1:52:12 PM |
| Posted by Xlance at Apr 14, 2026, 11:55:48 AM |
Re: Modeller 3D plugin - Make the coordinate spinners a little larger, the decimal number is only displayed half with two digits before the decimal point. Most sizes used in Sweet Home 3D are between -1000 and 1000 and the precision is 1mm = need to completely display 999.9 or if possible -999.9. It looks like there is room for it in the panel. Fixed- Don't forget to look at the selection process. Actually the use of right click is very common and convenient- close and start the plugin again. Import another object from a different location. Now it asks for a filename to store? <enter> and (maybe) the object is stored somewhere but I can't find it. Probably no save at all. Works fine with me- even after closing Sweet Home 3D and opening the same project again the plugin does no longer display the save/cancel buttons. - all textures are lost, everything gets the same material definition. Fixed for *.obj and *.3ds- Imported *.dxf files with Arcs, Splines, Lines or Mixed. Fixedhttps://www.mediafire.com/file/cwxkgal36msa8l5/Modeller3D-1.4.5.7.sh3p/file ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
Current timezone is GMT Sep 23, 2026, 1:52:12 PM |
