Print at Oct 1, 2026, 3:51:58 AM
Posted by Puybaret at Aug 24, 2010, 3:47:01 PM
Re: Bug on open door
I didn't forget anything and this is more like a complicated enhancement than a bug. wink
Here's an other workaround easier that db4tech's one:
- Add first a Door frame at the place you want while magnetism is active.
- Then add the Open door at the same place with disabled magnetism (press down the shift key to disable temporarily magnetism), using Furniture > Align menu items and arrow keys to help you place it correctly.
- Finally if needed, group the two items to avoid future auto resize.
See the joined example.
Attachment OpenDoorInThickWall.sh3d (23560 bytes) (Download count: 300138) (An open door in a thick wall)
