Print at Sep 23, 2026, 1:52:32 PM
Posted by Keet at Apr 21, 2026, 10:23:31 AM
Re: a curved wall
The 4 walls way to create an oval is obsolete since the regular room plugin was introduced. There's a much better and easier method now.
Make sure you have the Advanced Edit plugin installed too. (that one should be installed by default!)
Using the Regular Room plugin: create a room as a circle with a sufficient number of sides.
Select the room and click the icon in the toolbar for "Resizes all selected items".
In the resize dialog uncheck the "Keep aspect ratio" checkbox. Now you can either change the height or the width to get a perfect oval. Click Ok to resize the room.
Select the "Create wall" tool from the toolbar and double-click on the room to create the walls around the room.
You can still change the oval walls after you created them by using the same resize function on the selected walls.
