Print at Sep 28, 2026, 1:18:44 PM
Posted by db4tech at Aug 25, 2010, 10:48:46 PM
Re: Modifiable room shapes
Hi maker,
Hans means, that while using Sweet Home, when a room is designed and floor / ceiling is added, then the floor always appears at zero elevation, and there is no way to adjust the elevation of the built in floor. So another method must be used to produce a second floor.
I like to make my walls the full height of the building, then add a flattened box from the furniture list and texture it, or I make and texture the same shape in another 3D program (so I have more texture surface options) that box then acts as the second (or third and so on) floor/ceiling.
Hope that helps!
db4tech
