Print at Sep 28, 2026, 1:11:50 AM
Posted by danuntu at Aug 27, 2010, 6:28:53 AM
Re: SweetHome3d shut down after some seconds
My problem is similiar to the following thread with the exception that i use linux. Kubuntu 10.04 LTS to be exact. I have an older version of SweetHome 3D running on another linux box and it runs fine. But this one the the program opens for maybe a second then closes. Why?!?
I've updated my Java to Suns JRE 6 update 21. but still no SweetHome.
Thanks,
D
When I start "SweetHome3D.exe". The SweetHome3D window is displayed some seconds and then is closed. Same problem with "SweetHome3D.jnlp".
But, strangely for me, if I use SweetHome3D-2.0.jar, the software is entirely usable !
First lines of Error files "hs_err_pidxxxx.log" :
- With "SweetHome3D.exe", :
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=4088, tid=4016
# JRE version: 6.0_14-b08
# Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 )
# Problematic frame:
# C [atioglxx.dll+0x41084a]
- With "SweetHome3D.jnlp" :
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=1792, tid=3524
# Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86)
From which is coming this problem (also with 1.6, 1.7, 1.8) ?
Thanks.
[Note: this thread was started on sourceforge.net forums]
