Print at Oct 1, 2026, 3:37:05 PM
Posted by sjb007 at May 20, 2026, 11:06:56 PM
Re: How to put UI panels back to their original order
OpenJDK version 26.0.1
You're using a distro packaged version of SweetHome3D, yes?
Packagers like to remove redundant executables and libraries. In this case you appear to be using the systems Java runtime instead of the one bundled with SweetHome3D.
Very likely this is the issue and that following Keet's recommendation will fix it for you.
