Print at Oct 1, 2026, 1:59:16 PM
Posted by JosSc at Jun 1, 2026, 11:49:18 AM
Re: glase pane in door
Thank you. I can use your method whenever I have a door with a pane in it: then I can select the material and edit the file to make it transparent.
But unfortunately I don’t know how to get a pane in a door. I think I first have to put an invisible box in the door; then add a fixed window; and then make the window transparent with your method. Unfortunately the only invisible box I could find doesn’t work on a door, only on walls.
So I like to ask for your help again, starting with a standard door and made it green. Which steps need to be taken to get 9 small glass panes (in Dutch: negen ruitjes) in the upper half of the door.
Hope you can help me again.
