Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Copy / Paste Between Files » » » » Post: Re: Copy / Paste Between Files |
Print at Oct 2, 2026, 10:01:21 PM |
| Posted by KevinAyala at Jun 4, 2026, 12:58:19 PM |
Re: Copy / Paste Between Files TwistedLincoln I also have the same problem internittently. I haven't found a way to consistently fix it. Sometimes, if it's a large number of objects I'm copying, it's just a matter of waiting 10,20 30s between copying and pasting. Other times the pasting just doesn't want to work regardless - and you can kinda confirm this on the target model you want to paste into by looking at the Edit menu to see if the "Paste" option is enabled or greyed out. Just now I seem to have resolved the issue (this time) by separately closing/re-opening each model. [url=https://geodash.org/]geo dash[/url] BTW, drag/drop furniture objects between models doesn't work for me. I'm running SH3D v7.5 on Win11 Thanks for sharing. I'm experiencing a similar issue, although in my case it happens even with a small number of objects. Sometimes copy/paste works normally, and other times the Paste option is greyed out for no obvious reason. Reopening the models occasionally helps, but not always. Hopefully this is something that can be reproduced and fixed in a future update. |
Current timezone is GMT Oct 2, 2026, 10:01:21 PM |
