Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: I'd like to see... » » » » Post: Re: I'd like to see... |
Print at Sep 24, 2026, 4:37:10 PM |
| Posted by rooperi at Aug 31, 2010, 1:26:30 PM |
Re: I'd like to see... Thank You for your response. Re rotating multiple objects: Thanks, that's helpful too, but I actually meant rotating walls and floors too. Say I have 2 buildings a house and a separate garage, and the garage is at a (say) 23 degree angle to the house. It would be easier to draw it straight up and rotate the entire building when complete, instead of drawing everything at an angle. Sorry if I wasn't clear. Re interior Exterior walls: Building codes in South Africa specify outer wall (and load bearing walls) thickness of 220mm, inner wall 110mm. I thought it would be nice to switch between the 2 with a single click, instead of changing the default in the dialogue box. |
Current timezone is GMT Sep 24, 2026, 4:37:10 PM |
