Print at Oct 10, 2026, 11:32:15 AM
Posted by db4tech at Sep 16, 2010, 12:47:08 AM
Re: AdvancedRenderingMini-1.6.1 + new lights
AdvancedRenderingLights-1.6.1
Since a light bulbs brightness can now be controlled, and to make it easier, there is now just one colour of each light bulb, plus a new Daylight colour bulb! smile
AdvancedRenderingLights-1.6.1 for use only with the new AdvancedRenderingMini-1.6.1 (or a later AdvancedRendering version)
In the future I will probably just call them AdvancedRenderingLights, to make it easier for users to upgrade to later versions.
db4tech
Edit to add highlighted text:
Because several people have downloaded just the lights without the AdvancedRenderingMini-1.6.1, so they will see the cross-hairs in their renders.
Maybe I should have added both files together in a zip file in case the downloads are by none English speaking users?
Edit 2:
Just found a bug with the new lights, the cross-hairs lose their colours when returning to a previously made model.
Here is the bug fixed version that solves that problem!
[Note from moderator: I removed the buggy version to avoid confusion as requested by db4tech]
Attachment AdvancedRenderingLights-1.6.1.sh3f (132135 bytes) (Download count: 15445) (Bug fix version. Solves the problem of cross-hairs losing their colours)
