Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: New plugin: Advanced plan editing » » » » Post: Re: New plugin: Advanced plan editing |
Print at Sep 23, 2026, 11:21:11 PM |
| Posted by hansmex at Sep 16, 2010, 6:09:22 PM |
Re: New plugin: Advanced plan editing Tobias, Are we talking about the same plug-in? 1 - When I draw a room, select all four walls and access Edit -> Resize, I can resize the room by using the drop-down menu, setting it to exact or relative measurements, or to a percentage. X and Y can be individually changed, or Aspect Ratio can be checked. 2 - While nothing is selected, I have access to Edit but not to -> Resize. 3 - I draw four separate walls, together forming more a less a square, but without the ends of the walls touching. "Open corners", so to say. When I select all fours walls and then Edit -> Resize , I cannot see how I should connect the walls, and more in general, nothing happens. Based on your answer, I would expect the walls to be made longer, to the point that they form a closed quadrangle. START EDIT 4 - As to the nine "justification buttons": can you explain how to use them? I can see that the coordinates changes according to the button pressed, but it doesn't seem to make any difference. END EDIT Is it possible to write a detailed step-by-step tutorial with images on how to (a) edit room points, (b) create that new room, and (c) join or connect walls? Thanks for any explication you can offer. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 23, 2026, 11:21:11 PM |
