Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Feat. Req: Editing position and measurements of rooms numerically » » » » Post: Re: Feat. Req: Editing position and measurements of rooms numerically |
Print at Sep 24, 2026, 7:57:31 AM |
| Posted by starrunner at Sep 17, 2010, 9:08:27 AM |
Re: Feat. Req: Editing position and measurements of rooms numerically The command is correct, but you need a normal JRE or JDK, as the one that comes with SH3D has no "java.exe", only a "javaw.exe" which will suppress the console output. You could also use the following commands from the SH3D root directory to start your current installation (JAVA_HOME is the path to your normal JRE): set path=%PATH%;%CD%\lib |
Current timezone is GMT Sep 24, 2026, 7:57:31 AM |
