Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: AdvancedRenderingClassic-1.6.1 » » » » Post: AdvancedRenderingClassic-1.6.1 |
Print at Oct 10, 2026, 11:31:17 AM |
| Posted by db4tech at Sep 22, 2010, 10:30:50 PM |
AdvancedRenderingClassic-1.6.1Hi All, I've had a few requests for this now, so here is. AdvancedRenderingClassic-1.6.1 As per Emmanuel's wishes I've used a slightly different name. This is the standard size interface version, with the bug fixes, tweaks and new features found in AdvancedRenderingMini-1.6.1 ![]() New version 1.6.1 supersedes the previous version 1.6 Firstly Bug fixes / Improvements I discovered that both versions (full size and mini versions of AdvancedRendering-1.6) suffered from a button label problem that could easily be replicated. The issue also affected the French labels. Used a quick fix, (not connected with the word changes) which solves the problem for both English and French label texts. *** Slight modifications to some of the English button labels: Use light angle as power knob becomes Light bulb angle controls brightness Glossy becomes Gloss, this is so both Gloss and Silk labels are read in the same descriptive way, otherwise it would be necessary to use Glossy and Silky. Also for the future this then represents paint styles, Matt, Silk and Gloss. *** Have further tweaked the caustics (Compute glass transparency) settings which should allow lights placed a little further away to still pass through thick glass objects. This is only a slight improvement! Old: ![]() New: ![]() *** Adjusted light settings so multiple light sources are reduced while using a sky texture. The only downside (if "Add sunlight" isn't ticked) is the shadow on the opposite side of the building will be darker. Old: ![]() New: ![]() *** Introducing a completely new "Fast" render method! I'm trying this out to find users opinions. This should at least be as fast as before or with a few seconds. It has 2 main benefits and 1 slight downside. Firstly the slight downside: some shadow areas can be a bit more noisy, this can be tweaked further to make shadows less noisy, doing so has an impact on render speeds. Old: ![]() New: (as mentioned, nosier shadows) but lights and shadows are rendered correctly. ![]() Now for the 2 benefits: The banding problem seen during daytime "Fast" renders is completely overcome. Old: ![]() New: ![]() Soft shadows are now rendered while using "Fast" instead of multiple shadows, this also greatly improves lighting previews before doing a "Best" render. Old: Interestingly the original "Fast" render method produces more noise on the back wall in this scene. So I guess both have their good and bad points. ![]() New: ![]() Don't forget that all these renders are with the "Fast" setting so "Best" renders will look much better! *** Now for the new addition! ![]() Something many users have asked for. The ability to see where light bulbs are placed in the Sweet Home 3D preview window, allowing for easy positioning. The cross-hairs also indicate the light bulbs size but it is important to remember when resizing light bulbs to enter the same size in all furniture size fields (Width , Depth and Height) The light bulbs are sphere lights, entering a different size in only one field, still means the light increases in size in all directions, but the cross-hairs won't show this, unless the same size is entered in all fields. ![]() I'm hoping when the lighting system is integrated into Sweet Home that the size fields will have the size proportions locked, so it will only be necessary to enter a size in one field. The new AdvancedRenderingLights-1.6.1 are needed to see the new cross-hairs and they must only be rendered with AdvancedRenderingClassic-1.6.1 (or AdvancedRendingMini-1.6.1) or newer. If they are used with an older render version the cross-hairs will be visible in the render! This is what will happen, if the new lights are used with an older AdvancedRendering version: ![]() The new AdvancedRenderingClassic-1.6.1 is fully backwards compatible, so all previously used BasicLights, or BasicPlusExtraLights (or for users not wanting to use AdvancedRendingLights-1.6.1) should render without problems. I do hope these updates will be useful and help users with their renders. ![]() db4tech The new files are attached below this message. AdvancedRenderingLights-1.6.1 ---------------------------------------- |
Current timezone is GMT Oct 10, 2026, 11:31:17 AM |
