Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Unexpected rendering... » » » » Post: Unexpected rendering... |
Print at Sep 29, 2026, 10:52:24 AM |
| Posted by hansmex at Sep 24, 2010, 4:16:14 AM |
Unexpected rendering... Emmanuel, db4tech, Playing around I came across some unexpected behaviour in one of my renders. What you see is a wall made of transparent building blocks. Although all blocks are the same, the central cylinder in some of the blocks is rendered transparent. Maybe there is an explanation for this? Or is it an undocumented feature? ;-) I also include: - the large picture (1200x800 pixels) - the building block file (bouwsteen.sh3d) - the 3d model file (bouwsteen test2.sh3d) Inspiration came from this building by Jean Nouvel. EDIT After posting this thread, I noticed that I hadn't checked "glass transparency". I made new renders with glass transparency checked. The inside-out view is approx. the same, although different cylinders are transparent. When seen from the outside all cylinders are correctly rendered. Changing ceiling light to light bulbs has no effect on this strange behaviour. END EDIT Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 10:52:24 AM |
