Print at Sep 29, 2026, 10:06:30 AM
Posted by whippetsleek at Sep 24, 2010, 1:29:00 PM
Re: Unexpected rendering...
This is the result I got. All I did was ungroup all the blocks, and reinsert them into the wall. I would suspect (and guessing) the grouping was causing some faces to cause a conflict with the wall surface? The blocks though in my render are now the same thickness of the wall, so this probably wouldn't work for if you had a specific reason for a thicker wall block.
