Print at Oct 1, 2026, 3:12:30 PM
Posted by whippetsleek at Sep 27, 2010, 11:35:00 PM
Re: Java Question
The Ubuntu Software Center has the jre 5, I was hoping to get the new jre 6. I can only find that at the Java website. I am also trying to install manually so that I know how to do it the next time in case I can't go thru the package installer. The instructions I recieved from the Ubuntu help forums were the same as what is on the Java site, on running as super user, changing permissions, and such. I have everything up to the actual unpacking of the software done, I was just hoping someone here might have had the same problem, and found a solution. I will likely just go ahead and download jre 5 and update it afterward if I can't find a solution
