Print at Oct 10, 2026, 11:30:17 AM
Posted by Puybaret at Sep 28, 2010, 8:58:03 AM
Re: Sweet Home 3D 3.0
An additional note about compatibility with SH3D files created with previous versions:
- The compass rose isn't shown. Make it visible with Plan > Modify compass… menu item.
- The values set for lens, date, time, time zone, North direction, latitude, longitude and ceiling lights in the Advanced rendering plug-in aren't used in version 3.0 and you'll have to copy them back if needed. By default, date/time is set to midday today, latitude/longitude are set from your time zone and ceiling lights are turned on.
- All existing lights are turned off and the angle set on light sources isn't used for its power level. Adjust the power of each light with the new Light power spinner available in Furniture modification dialog. You can edit the power of more than one light at a time by selecting them and choosing Furniture > Modify... menu item.
I hope these changes won't bother you too much.
