Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: New plugin: Advanced plan editing » » » » Post: Re: New plugin: Advanced plan editing |
Print at Sep 26, 2026, 1:49:49 PM |
| Posted by hansmex at Oct 4, 2010, 11:06:26 AM |
Re: New plugin: Advanced plan editing Tobias, 1 - Split wall --> Join walls What I would like here, is in fact a kind of Undo for the Split wall function. It should (re-)connect two parts of a straight wall. 2 - I am in the process of writing a tutorial for all plug-ins. This is an image I made to illustrate the behaviour of the Connect walls function as it behaves now. EDIT Here is the correct picture. END EDIT I made a new image that better shows what I would like. First it shows current behaviour: an open room can be closed, correcting a "mistake" that often happens. The second part of the image shows something that might be a useful new function. EDIT 2 I think this could be implemented by asking "Wall 1: Connect end point or start point?" and then "Wall 2: Connect end point or start point?" END EDIT 2 ![]() There is a variation on the second example: joining walls in a T-junction or a Y-junction, although its use would be more limited. I hope this clarifies what I meant. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 26, 2026, 1:49:49 PM |
