Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: New plugin: Advanced plan editing » » » » Post: Re: New plugin: Advanced plan editing |
Print at Sep 24, 2026, 6:22:36 AM |
| Posted by starrunner at Oct 4, 2010, 12:06:24 PM |
Re: New plugin: Advanced plan editing Hi Hans, for the "Join walls" function - I could write that action, for sure. But I'll wait until Emmanuel moves the wall actions into their own menu - as you already mentioned in the 3.0 thread, the menu is quite huge, right now. And as long as you can achieve the described behaviour with small effort (in the way I mentioned it), I think its not that important. To the images: The "connect walls" action has nothing to do with the order the walls were drawn (as long as you select one by one): It connects the endpoint of first selected wall with the startpoint of the second selected wall. To achieve the desired behaviour of your last example, select the walls in the right order and reverse the walls before the action if necessary. |
Current timezone is GMT Sep 24, 2026, 6:22:36 AM |
