Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Increase memory » » » » Post: Re: Increase memory |
Print at Oct 7, 2026, 5:40:08 AM |
| Posted by fhoofman at Oct 7, 2010, 10:11:45 PM |
Re: Increase memory You can change the max memory used by Sweet Home 3D only on the installer version, by changing the value in the -Xmx Java option: - under Linux, edit SweetHome3D script and update the 1024 value in the option -Xmx1024m, - under Mac OS X, right click on Sweet Home 3D application icon, select Show Package Contents, open Contents folder, edit Info.plist file by dragging its icon on TextEdit application, and update the 1024 value in the text <string>-Xmx1024m</string>, - under Windows, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the max memory Java option in that file, for example: -Xmx2048mOn all systems, 1024m means 1024 MegaBytes. I'm running windows 7, and I create text file SweetHome3D.l4j.ini. content of the text file: -Xmx2048m when I run the exe file, there's an error occur " Could Not Create The Java Virtual Machine" |
Current timezone is GMT Oct 7, 2026, 5:40:08 AM |
