Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 3.0 » » » » Post: Re: Sweet Home 3D 3.0 |
Print at Oct 11, 2026, 2:54:25 AM |
| Posted by hansmex at Oct 22, 2010, 1:08:22 PM |
Re: Sweet Home 3D 3.0 Chris, In Modify walls you can only change the X,Y coordinates, not the radius. Example: - I draw a wall that has XY coordinates 0,0 and 300,0 with highest point of arc at 150,100 - using Modify wall I change the coordinates, so that the "new" wall has XY coordinates 0,0 and 500,0 - the result is that the highest point of the arc is now at 250,150 That means that the form of the arc stays the same, only the size changes. What is needed is - an option to change the angle of the arc which is indicated in the small yellow pop-up window next to the cursor when you draw the arc. - the option to hit Enter to get access to that yellow pop-up, so you can use the keyboard to enter exact length and angle, just as when drawing a "normal" wall. Maybe this could be a future feature? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 11, 2026, 2:54:25 AM |
