Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: workaround javaws worked, then stopped. (quits when preferences selected) » » » » Post: Re: workaround javaws worked, but needs downloads each time I use it... |
Print at Sep 24, 2026, 11:36:02 PM |
| Posted by Puybaret at Nov 1, 2010, 7:45:06 PM |
Re: workaround javaws worked, but needs downloads each time I use it... It's great you succeed to build SweetHome3D-2.6.jar, but you should build SweetHome3D-3.0.jar from CVS sources. Don't worry for the warnings. If program fails, it might be because of the JRE you use. Give its full path when you launch Sweet Home 3D: /path/to/java -jar SweetHome3D-3.0.jar---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 11:36:02 PM |
