Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: saving & using modifed furniture » » » » Post: Re: saving & using modifed furniture |
Print at Sep 29, 2026, 8:28:30 AM |
| Posted by hansmex at Nov 4, 2010, 9:02:23 PM |
Re: saving & using modifed furniture Garth, Follow this link and look at the picture. Window 3 is referred to as The Plan. Turns out I misunderstood you. To modify a wall or a piece of furniture, you have to select it in The Plan. So, activate The Plan window, select/highlight The Model and click Furniture --> Modify, or select/highlight The Wall and click Plan --> Modify walls to change the item you chose. A faster way is to double-click the item you want to change, which works for both furniture and walls. If you are using a laptop and its touchpad, you may consider buying a (small) mouse to avoid too many hit-and-misses. I recommend you read the section(s) about exporting and importing furniture to familiarize yourself with these important features. It allows you to export an adapted window and then re-import it. However, I think that once you get to know the program better, you will find that making changes is pretty fast and easy. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 8:28:30 AM |
