Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: furniture library » » » » Post: Re: furniture library |
Print at Sep 29, 2026, 5:30:06 PM |
| Posted by hansmex at Nov 13, 2010, 1:38:04 AM |
Re: furniture library Alexey, - In your design, select the model that you want to share with a friend. - Now do CTRL-C to copy it. - Start a new instance of SH3D - Copy your model in this new, empty SH3D with CTRL-V - Now, in the menu click 3D view --> Export to OBJ format - A new window opens, where you can choose a directory, and give the model a name - Two files are created: modelname.obj and modelname.mtl - Give both files to your friend - He/she can use the model after importing it with Furniture --> Import furniture If you want, you can compress the two files into a zip-file, which also can be directly imported the same way. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 5:30:06 PM |
