Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: strange door behavior » » » » Post: Re: strange door behavior |
Print at Sep 24, 2026, 5:49:08 AM |
| Posted by hansmex at Nov 14, 2010, 9:37:05 PM |
Re: strange door behavior Macfrog, 1 - Another suggestion: load your file, select everything with CTRL-A, then change all the furniture to a colour, and all walls to a colour. Save it with a different name. 2 - Close SH3D and start it again, then load your file again to see if it works better. This should (normally) free up memory. 3 - I don't know much about Mac and Java, but it should work. Apple is dropping Java support, so you may want to change to a different operating system? Try Ubuntu 10.10 4 - Reduce your textures to 512x512 pixels or 1024x1024 pixels. Try to avoid transparency in your textures, to avoid possible problems. 5 - You can't edit posts, unless you have been granted privileges. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 5:49:08 AM |
