Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: add a member to HomePieceOfFurniture » » » » Post: add a member to HomePieceOfFurniture |
Print at Sep 24, 2026, 3:37:42 AM |
| Posted by ckuppel at Nov 15, 2010, 9:43:31 AM |
add a member to HomePieceOfFurniture hello everyone, I try to edit the stucture of the "HomePieceOfFurniture" model by adding member. I alredy added the member, the getter and the setter, i modified the different views by adding an input field for this member (import and edit by double clicking on the object on the plan 2D). I don't know where (or when) the listener witch use the setters of "HomePieceOfFurniture" is called. this is a list of file modified : HomePieceOfFurniture.java homeFurnitureController.java When i importing a furniture or when modify one, i fill my text input associated to the member, then there the value of the memberis still Null. Do someOne has an Idee? Thank you [Note from moderator: please no translation. If you prefer to speak French, please post in the French section] |
Current timezone is GMT Sep 24, 2026, 3:37:42 AM |
