Print at Sep 26, 2026, 3:21:22 PM
Posted by Puybaret at Nov 15, 2010, 4:41:44 PM
Re: add a member to HomePieceOfFurniture
Sorry, but no one will be able to find a bug in your code, if he doesn't see the part you changed!
I suggest you to use a debugger to be sure that you set the fields and the variables values as expected.
By the way, "witch" is "sorcière" but I guessed you wanted to use "which" instead! wink
