Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Advanced render problem » » » » Post: Re: Advanced render problem |
Print at Sep 29, 2026, 10:05:00 AM |
| Posted by hansmex at Nov 18, 2010, 5:01:55 PM |
Re: Advanced render problem Crafty, Both models rendered correctly in v2.6 and v3.0, except the left-most door of the right cabinet: its centre panel stays grayish. The problem clearly lies with your model(s). At 2.3 Mb your file is FAR too big for two simple cabinets. When I applied a texture of my own (that never causes problems), I noticed that the surface of the right cabinet is divided into postage stamp-sized squares. I saw it's a DAE model, and these are known to cause problems every now and then. Try the same design with cabinets from the standard SH3D library. If you want to keep the texture, you can easily extract it from the SH3D file. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 10:05:00 AM |
