Print at Sep 29, 2026, 1:35:12 AM
Posted by whippetsleek at Nov 18, 2010, 8:51:51 PM
Re: Advanced render problem
Crafty... When you use Sketch, make sure you try to texture both sides of the model. If you select an area of your model, right click, and select reverse face to apply the same texture to both sides of the face. DAE models are always 2 sided, and this can cause problems with SH3D. I hope this helps. smile
