Print at Sep 29, 2026, 10:14:38 PM
Posted by PtiNounours at Nov 18, 2010, 9:39:45 PM
Re: Advanced render problem
For export file Collada (dae) Sketchup:
1 - in options, disable export faces both sides.
2 - Enable triangulate the faces (heavier, but avoids the problem of mesh). Enable export veneer textures; normal!
3 - before export, pass the display model in monochrome.
4 - The visible faces must be white. The faces gray that are invisible , and will not be exported. It is therefore necessary to reverse the gray faces visible that are on the faces of the model. (There are several plugins that do that very well).
This method works well for importing into SH3D.
Sketchup modeling has brought to all.
