Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 3.0 » » » » Post: Re: Sweet Home 3D 3.0 |
Print at Oct 11, 2026, 4:56:09 AM |
| Posted by hansmex at Nov 20, 2010, 12:32:01 AM |
Re: Sweet Home 3D 3.0 Chipmaster, Most probably this "problem" is not a problem. Try this, and do it exactly in this order: - draw you walls - insert your doors - draw your floor If you do things in this order, the door makes a hole in the wall, and the floor fills half that hole. If you first draw the floor, and then insert the doors, the floor isn't adapted to the inserted door, and the ground colour or texture is visible. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 11, 2026, 4:56:09 AM |
