Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: DAE model with render problem » » » » Post: Re: DAE model with render problem |
Print at Sep 29, 2026, 11:38:05 PM |
| Posted by hansmex at Nov 21, 2010, 10:56:09 PM |
Re: DAE model with render problem Emmanuel, I think I found a solution! A few days ago PtiNounours posted this message. Having finally been able to install SketchUp, I decided to install the plug-in he mentioned: FaceFront. After activating the plug-in, you "paint" over (parts of) your model and it reorients the faces of the model. In SketchUp you can't see a difference, but there definitely is a difference in the DAE-file when it's imported in SH3D. I treated two paintings this way, then did at least 5 renders, and each one came out correct. Hans ![]() ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 11:38:05 PM |
