Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Sweet Home 3D usability » » » » Post: Sweet Home 3D usability |
Print at Sep 30, 2026, 6:20:05 PM |
| Posted by chipmaster at Nov 25, 2010, 12:40:52 PM |
Sweet Home 3D usability Chipmaster, Most probably this "problem" is not a problem. Try this, and do it exactly in this order: - draw you walls - insert your doors - draw your floor If you do things in this order, the door makes a hole in the wall, and the floor fills half that hole. If you first draw the floor, and then insert the doors, the floor isn't adapted to the inserted door, and the ground colour or texture is visible. Hans Hans, I suggest to create intuitive user interface and logic as far as possible. I understand this rule as a developer but I don't understand it as a common user. If this sequence can be done by user using standard UI, why it can't be done inside the program automatically? I think common user should not know that there is a right order. Or maybe it makes sence to add some "foolproof" [Note from moderator: I split the thread "Sweet Home 3D 3.0" because this thread is already quite big already] |
Current timezone is GMT Sep 30, 2026, 6:20:05 PM |
