Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Advanced Photo feature... » » » » Post: Re: Advanced Photo feature... |
Print at Oct 1, 2026, 4:51:14 AM |
| Posted by Puybaret at Dec 2, 2010, 8:22:05 AM |
Re: Advanced Photo feature... There's no eyedropper in Sweet Home 3D. I know the current color chooser isn't that nice but you'll have to live with it for a while. Latitude and longitude are set automatically when you create a new home from the time zone of your operating system. Building the list of 600+ geographic locations from known time zones took me already more than one day (there are even some exotic ones for a few small islands that will probably be never used!), and I can't do better as there's no GPS in a computer, and even if there was one, it won't be so easy to get information from it in Java. This means that if the time zone is correct when you create your home, you should check whether the latitude and longitude are correct or not, and if you change the time zone, you must change the latitude and longitude (this is probably your case). Here are some web sites where you can get latitude and longitude of known places: http://www.wikipedia.org/ http://www.racerecon.com/trailrecon/gmaps/Cha...enScraping/scrape_me.html http://www.infoplease.com/ipa/A0001769.html http://www.realestate3d.com/gps/world-latlong.htm Caution: Sweet Home 3D uses decimals of degrees and not minutes/seconds. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 4:51:14 AM |
