Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: bug: undo doesn't return texture to colour » » » » Post: Re: bug: undo doesn't return texture to colour |
Print at Oct 3, 2026, 8:56:33 AM |
| Posted by wrosun at Dec 3, 2010, 7:46:33 AM |
Re: bug: undo doesn't return texture to colour Hello hans! I dont know about java so i cannot tell you the technical problem but i found out one thing since you boxes are group in several stepslike two boxex at first two steps and three for another three steps and like that it might be the problem when i ungrouped all the boxes and changed the texture and finally groupd them all at once it doesnot show the problem you have said......and you way of making the stairs i found it quit difucult and no offence but it is annoying to change or modify. if i were designing stairs like your i would use single box and increase elevation only because i thing it will use less boxes and the file will be less in size and rendering would be easy as well..... |
Current timezone is GMT Oct 3, 2026, 8:56:33 AM |
