Print at Sep 29, 2026, 10:15:03 PM
Posted by hansmex at Dec 4, 2010, 4:13:57 PM
Re: the render stop before it finish
Yudi,
Thanks for sharing your file. On my (Ubuntu) PC the render stopped after a few seconds. I'll have to investigate what the cause is. As soon as I know more, I will post it here.
EDIT
I already have a suspect.
The couch and the staircase are 3DS files, which you probably imported as a zip-file. Inside the file are also gsm-files. Try to unzip the file and import only the 3ds file, without the gsm part. Maybe that will solve the problem.
When I delete the three tangga files, the rest renders without a problem.
END EDIT
